Why Fueling Shifts Between Seasons
Endurance athletes know that training doesn’t stop when the weather changes, it just means more training will take place indoors. But this shift also means the body’s fueling and hydration needs change dramatically.
Environmental factors, session structure, and physiological stress all change how your body uses energy and fluids. Temperature, sweat rate, and workout duration can impact everything from carbohydrate oxidation to electrolyte loss.
That’s why your fueling strategy should evolve with the seasons. Whether you’re sweating through an indoor trainer ride or tackling long summer miles, we recommend Momentous to help fill key gaps in energy, hydration, and recovery so that you can perform at your best in any environment. Momentous products are built on three non-negotiables:
- Rigorous Third-Party Testing: Every product they offer is independently tested by NSF for Sport® and Informed Sport to verify purity, potency, and label accuracy. This is their standard—not the industry standard. Suitable for Olympians, professional athletes, and anyone who refuses to compromise.
- Science-Backed Ingredients: They use only the most bioavailable, clinically supported forms of nutrients, in the precise amounts needed for optimal absorption and efficacy.
- Expert-Designed Formulas: Partnering with world-leading experts, together Momentous creates formulas that meet your most impactful nutrient needs to help power Performance for Life™.
Main Differences in Fueling: Outdoors vs. Indoors
When it comes to training indoors, this can often mean greater heat stress, sweat loss, and faster energy depletion, even in shorter sessions. Outdoor training demands steady fueling for longer durations, with easier-to-read environmental cues.
| Factor | Outdoor | Indoor | Implication for Fueling |
| Temperature | Variable (sun, wind, humidity, shade) | Often hotter due to limited airflow | Higher sweat rates indoors → more fluid/electrolyte replacement |
| Sweat Rate | Moderate, visible | Often higher, less obvious | Track and replace fluids carefully indoors |
| Session Duration | Usually longer | Often shorter but higher intensity | Outdoors → steady carbs; indoors → Pre-workout fueling + intra-workout fueling |
| Energy Expenditure | Variable due to terrain and wind | Feels harder at same power | Indoor sessions may require more careful energy planning despite shorter duration |
| GI Comfort | Easier to digest foods | Heat + humidity can increase GI issues | Indoor fueling may favor liquids or easily digestible carbs |
How Momentous Products Support Indoor Training
Indoor training can often elevate core temperature, accelerate fatigue, and make hydration harder to gauge. Endurance athletes know that consistency is the cornerstone of a successful training and race season; the base miles undertaken in the winter months often lay the foundations for the year ahead. That’s why it’s important to do all you can to ensure your body and mind are ready for each training session, and set up to maximize recovery afterwards. Remember that when training indoors your sweat loss indoors can be 20–30% higher than you realize.
We are accustomed to supporting athletes and enabling them to do what they love—for longer. Our products are designed to support energy availability, recovery, and joint health, all of which are fundamental to optimizing indoor training. Here’s how:
Pre-training:
- Collagen Peptides or Collagen Shot: Used and trusted by more than 200 pro and college teams, collagen can help improve joint health and mobility, support soft tissue development, and expedite muscle recovery and soreness.
- PR Lotion®: PR Lotion delivers sodium bicarbonate directly through the skin to help buffer lactic acid, reduce muscle soreness, and improve training capacity. Used by elite athletes across endurance and power sports, this topical formula supports high-intensity performance without the GI discomfort often associated with oral bicarbonate.
Intra-training:
- Fuel: A carb + electrolyte drink for workouts over 60 minutes—perfect for those higher-intensity trainer rides where you want to keep glycogen stores topped off.
- Vital Aminos: Packed with all nine essential amino acids, Vital Aminos can help increase energy production, support muscle maintenance, and reduce breakdown during repeated hard efforts. It can be consumed pre- and post-training too.
Post-training:
- Recovery: The perfect shake to reach for when you get off the trainer, Recovery is a performance-focused post-workout formula designed to optimize muscle repair, replenish glycogen stores, and reduce exercise-induced soreness. Featuring a clinically supported 2:1 ratio of fast-acting carbohydrates to grass-fed whey protein, plus amino acids and electrolytes, it delivers comprehensive recovery support in one simple shake.
- Protein: Support lean muscle mass, optimize recovery, and ensure you hit your daily protein intake with our grass-fed Whey or 100% Plant Protein powders. Both are used and trusted by elite athletes and everyday high performers.
- Magnesium Malate: A highly bioavailable form of magnesium that supports energy production, muscle recovery, and overall metabolic health. Popular with athletes looking to expedite muscle recovery, reduce soreness, and promote mood balance and restful sleep.
- Vitamin D3 5000 IU: Support bone and muscle health as well as immune function with Vitamin D3, which is also available in 2000 IU capsules. Particularly important during low-sunlight months.
- Turmeric: Helps reduce inflammation and muscle soreness.
- L-Glutamine: Especially important during periods of intense training and physical stress, L-Glutamine can help support gut and immune resilience as well as stimulate muscle protein synthesis.
How Momentous Products Support Outdoor Training
Outdoor sessions are typically longer, more variable, and place sustained demands on joints, muscles, and energy reserves. While it can be easier to assess hydration and fueling needs in real time compared to indoor training, it’s still essential to begin sessions well fueled, hydrate and fuel consistently intra-workout, and then optimize recovery and adaptation by refueling within your post-workout recovery window. Here are a few ways Momentous products can help:
Pre-training:
- Collagen Peptides or Collagen Shot: Reduce injury risk, build resilience, and minimize muscle soreness by consuming collagen pre-workout.
Intra-training:
- Fuel: Fuel uses Palatinose™, a low-GI carb made from beet sugar, designed to provide steady energy without blood sugar spikes or crashes—perfect for long rides and runs when you want to keep energy levels stable and effort sustained.
- Vital Aminos: Preserve lean muscle and support endurance during longer sessions by taking on essential amino acids.
Post-training:
- Recovery: Loved by pro and everyday endurance athletes alike, make your post-workout recovery shake as simple, tasty, and effective as possible by reaching for Recovery. It’s designed to optimize muscle repair, replenish glycogen stores, and reduce exercise-induced soreness with its 2:1 ratio of fast-acting carbohydrates to grass-fed whey protein.
- Whey Protein: Support lean muscle mass, optimize recovery, and ensure you hit your daily protein intake with our grass-fed Whey or 100% Plant Protein powders.
Practical Takeaways
Your body’s fueling demands shift with the seasons—and your nutrition should too.
When training indoors, focus on:
- Warming up well and supporting joint health.
- Pre-fueling before workouts to ensure available energy.
- Hydrating deliberately, as sweat loss can be 20–30% higher than you realize.
When training outdoors, prioritize:
- Steady energy intake through long efforts.
- Consistent hydration and electrolyte replacement to sustain endurance and longevity.
- Post-session refueling with protein, carbohydrates, and healthy fats to accelerate recovery and adaptation.
Regardless of where you train, the principles remain the same: fuel consistently, hydrate deliberately, and recover intentionally. Pair these with adequate sleep and rest, and you’ll build the kind of resilience that carries through every season. From the trainer to the trails, Momentous is here to help you fuel smarter, train stronger, and recover better so that you can perform at your best, no matter the season.
