KICKR Headwind Bluetooth Fan
$319.99
The KICKR HEADWIND is the first ever smart fan, designed with the cyclist in mind. Its Targeted Airflow Pattern mirrors the shape and position of a cyclist's body while riding. The KICKR HEADWIND is sensor controlled so as your speed or heart rate increases, so will the fan speed, and there are also 4 manual speed settings should you want to set your own ideal airflow. With speeds of over 30 mph (48 kph), the KICKR HEADWIND will keep you cool during the toughest training sessions.
  • New! Adaptive Cooling Mode - The fan speed in Adaptive Cooling mode ramps up with power and ramps down with HR.
  • New! KICKR RUN Speed Integration - KICKR RUN athletes can now enjoy automatic fan adjustments based on their pace.
  • New! CORE body temperature support - Change fan speed based on your body or skin temperature when paired to CORE body temperature sensor.
  • Manual Mode: Select from four speed settings to set you ideal airflow
  • Speed Mode: Pair to KICKR or speed sensor to match fan speed to bike speed
  • Heart Rate Mode: Pair to ANT+ heart rate monitor to increase airflow as heart rate goes up
Fitness2021
Bicycling2020
Di Award
Rider Optimized
The targeted airflow pattern of KICKR HEADWIND is designed to tunnel the fan’s airflow at your body, where you need it most, providing a superior outdoor feel—indoors.
KICKR HEADWIND Smart Fan
The targeted airflow pattern of the KICKR HEADWIND is designed to mirror the shape and position of a cyclist’s body while riding, with wind speeds topping out at 30 mph (48 kph) to keep you cool during your hardest efforts.
KICKR HEADWIND Smart Fan in use
KICKR HEADWIND Features
Powerful Airflow
With wind speeds topping out at 30 mph (48 kph) the KICKR HEADWIND will keep you cool during your hardest efforts.
The targeted airflow pattern of the KICKR HEADWIND is designed to mirror the shape and position of a cyclist’s body while riding on a bicycle.
Sensor Based Fan Speed Control
Control the speed of your KICKR HEADWIND by pairing your Bluetooth or ANT+ speed sensor, heart rate monitor, KICKR RUN treadmill or KICKR smart trainer directly to the fan. As your speed or heart rate increases, so will the fan speed.
App Based Fan Speed Control
Use the Wahoo App to control sensor pairing and fan speed.
Four Manual Fan Speeds
Control the KICKR HEADWIND with a simple press of a button. Four (4) preprogrammed fan speeds allow you to select your ideal airflow.
KICKR Desk Compatible
The KICKR HEADWIND was specially designed to fit with the KICKR DESK. The wheels on the KICKR HEADWIND allow you to roll the fan into position when it is attached to your KICKR DESK.
Connectivity
Bluetooth
ANT plus ANT+
30 mph / 48 kph
Max Fan Speed
4
Manual Fan Speeds
Part Number
WFBKTR7
Motor Spec
120V 60Hz
Dimensions (leg tucked)
16"L x 12"W x 19"H (41cm x 31cm x 48cm)
Dimensions (leg extended)
18"L x 12"W x 19"H (46cm x 31cm x 48cm)
Weight
12 lb / 5.5 kg
Max Fan Speed
30 mph / 48 kph
Wireless Software Updates
Yes
Connectivity
  • Bluetooth – pair to phone to control fan speed via app
  • ANT+ – pair to speed sensor, heart rate monitor, or smart trainer to control fan speed
Adjustable Leg
Yes – 2 Positions
Compatible Sensors
  • Most ANT+/BLE running speed sensors
  • Wahoo TRACKR Heart Rate Monitor and ANT+/BLE heart rate monitors
  • Wahoo RPM Speed and ANT+/BLE speed sensors
  • CORE body temperature sensors
What’s in the Box
  • KICKR HEADWIND Unit
KICKR HEADWIND fan speed and pairing controls detail
KICKR Headwind
Bluetooth Fan
