KICKR BIKE with 1-Year Zwift Membership
$4,099.99
Better together. KICKR BIKE blurs the line between virtual and reality with integrated grade changes, customizable gearing, and simulated shifting to create the most powerful, personalized, and realistic indoor cycling experience. Purchase KICKR BIKE with a 1-year Zwift membership for indoor cycling fun with serious fitness results.
Purchase includes a 1-year membership to Zwift. Membership requires Zwift account and auto-renews after 12 months at €149.99, $149.99, £129.99, $189.99, $199.99, ¥15,000 unless cancelled.
Billing information required to redeem. Terms apply.
  • FEATURES
    • Real-time physical grade changes for immersive and realistic rides.
    • Accurate power measurement of +/- 1% with up to 2500W of resistance.
    • Virtually silent operation
    • NEW - Direct Connect and WiFi Connectivity
    • NEW - Odometer tracks total trainer mileage
    • Coming Soon - Race Mode uses WiFi capability to broadcast power up to 10x faster for competitive advantage at critical race stages. Learn more.
  • SPECS
    • Power Accuracy: +/- 1%
    • Maximum Power Output: 2500W
  • SETUP
RECOMMENDED ADD-ONS
WAHOO X Annual Membership
WAHOO X ANNUAL MEMBERSHIP
$149.00
No matter how you choose to ride or train, Wahoo X is the easiest way to get all your favorite training experiences for one incredible price.
KICKR Headwind Bluetooth Fan
KICKR HEADWIND BLUETOOTH FAN
$299.99
This smart fan adjusts to match your riding speed or heart rate, or select manual settings.
Wahoo SPEEDPLAY ZERO dual-sided stainless pedals.
SPEEDPLAY ZERO PEDALS
$229.99
Stainless steel dual-sided bike pedal and cleat system offer a customized fit for peak power transfer.
Wahoo KICKR Trainer FloorMat
KICKR TRAINER FLOORMAT
$79.99
RIDE THE REVOLUTION
KICKR BIKE smart bike trainer is compatible with KICKR Trainer Accessories, including the KICKR DESK and KICKR HEADWIND Smart Fan, allowing you to build the ideal setup to make your smart bike experience next level immersive.
RIDE REAL.
This smart bike combines KICKR’s legendary ride feel with cutting-edge innovations like integrated grade simulation to create an indoor cycling experience that blurs the line between virtual and reality.
MAX GRADE SIMULATION
10% 12% 16% 20%
MIN GRADE SIMULATION
10% 12% 15% 20%
MAX POWER (WATTS)
1500w 1800w 2200w 2500w
KICKR BIKE FEATURES
REALISTIC RIDE FEEL
KICKR BIKE Smart Bike combines KICKR’s legendary resistance and grade simulation technologies to replicate the sensation of riding outdoors – including downhill simulation that allows you to maintain speed on virtual descents.
REAL-TIME PHYSICAL GRADE CHANGES
FIVE POINT ADJUSTABLE FIT
Adjust the fit of your smart bike to match your outdoor bike's geometry across 5 points - stack, reach, setback, saddle height, and frame height.
PROGRAMMABLE VIRTUAL SHIFTING
Customize the KICKR BIKE shifting controls to match shifters from the leading manufacturers - SRAM, Shimano, and Campagnolo.
PROGRAMMABLE GEARING
SEAMLESS CONNECTIVITY
Offering a robust 2.4 GHz Wi-Fi connection, up to 3 Bluetooth Connections, a direct connect port and ANT+/ANT+FE-C compatibility, KICKR BIKE smart bike pairs to most devices and applications so you have the most control over your training and ride data.
All Wahoo smart trainers and smart bikes come with a trial to Wahoo X, giving you immediate access to two completely unique indoor cycling apps through one account.
KICKR BIKE SPECS
TECH SPECS
  • Maximum Power Output: 2500 Watts
  • Product Weight: 93 lb / 42 kg
  • Drivetrain: Belt Drive
  • Resistance Type: Electromagnetic and enhanced motor
  • Power Accuracy: +/-1%
  • Crank Arm Lengths (mm): 165, 167.5, 170, 172.5, and 175
  • Rider Height Range: 5 feet (152 cm) to 6 feet 4 inches (193 cm)
WHAT’S IN THE BOX?
  • KICKR BIKE smart bike
  • AC Power Adapter
  • Handlebar Assembly
  • Does not include pedals
SUPPORTED DEVICES
  • iPhone / iPad: iOS 13 or newer
