KICKR CORE 1 with Zwift Cog and Click
$349.99 $534.99
KICKR CORE 1 with Zwift Cog and Click unlocks a world of indoor cycling fun and fitness. With Zwift Cog pre-installed it has everything you need to achieve your goals—plus, it’s compatible with almost any 8-12-speed bike.
Zwift Click effortlessly mounts to any handlebar for seamless, quiet virtual shifting. Experience smart resistance that perfectly mimics every climb and descent. Take your training to the next level with the built-in power meter.
  • Includes pre-installed Zwift Cog and Zwift Click virtual shifter
  • +/- 2% power accuracy
  • Measures speed, distance, power, and cadence data
  • Auto-calibration
  • View More
  • Compatible with almost any 8-12 speed bike
  • Maximum Power Output: 1800W
  • View More
KICKR Core Features
Zwift Cog
Zwift Cog is compatible with almost any 8-12-speed bike, unlocking maximum compatibility and keeping maintenance to a minimum—just jump on and start riding.
Zwift Click
Zwift Click controls your virtual gears and attaches seamlessly on any handlebar, putting intuitive virtual shifting at your fingertips.
Virtual Shifting
Quiet, smooth, and consistent - the virtual gearing of the Wahoo KICKR CORE Zwift One turns your bike into a smart bike.
Learn more about virtual shifting.
Real Ride Feel
Wahoo KICKR CORE Zwift One’s automatic resistance realistically matches the gradient of the virtual road. You’ll glide down hills and feel every climb, delivering an unmatched indoor cycling experience.
Power Meter
The heart of Wahoo KICKR CORE Zwift One smart trainer is its power meter, which levels up your training with tailored workouts and accurate training data.
KICKR CORE Benefits
KICKR CORE Zwift One Smart Trainer
Optimized flywheel technology
KICKR CORE features a 12lb flywheel engineered to provide riders with the precise inertia needed to recreate an outdoor ride feel while riding an indoor bike trainer.
Ready to ride
With Zwift Cog pre-installed, it has everything you need to achieve your goals—plus, it’s compatible with almost any 8-12-speed bike.
Ecosystem compatible
KICKR CORE seamlessly connects to the hardware devices and software platforms that make up the Wahoo indoor cycling ecosystem to give you endless ways to get fitter and faster through training indoors.
Power up
Ride The Revolution
This smart bike trainer is compatible with KICKR Trainer Accessories, including the KICKR CLIMB Grade Simulator and KICKR HEADWIND Smart Fan, allowing you to build the ideal setup to make your smart bike trainer experience next level immersive.
KICKR CORE Smart Trainer
Your Ride. Your Way.
Whether you have multiple bikes or multiple riders, KICKR CORE Zwift One accommodates almost any 8-12-speed bike to maximize compatibility and minimize set-up.
Max Grade Simulation
10% 12% 16% 20%
Max Power (Watts)
1500w 1800w 2200w
KICKR CORE Specs
TECH SPECS
  • Maximum Power Output: 1800 Watts
  • Product Weight: 40 lb / 18 kg
  • Drivetrain: Belt Drive
  • Power Accuracy: +/-2%
  • Connectivity: ANT+, ANT+ FE-C, and up to three Bluetooth Connections
  • Includes a pre-installed Zwift Cog (14-tooth single sprocket)
  • Adapters: Includes 130/135mm QR adapter & hub spacer, 12x142/148 adapter & hub spacer.
  • Zwift Click: Bluetooth communication; CR2032 battery powered
WHAT’S IN THE BOX?
  • KICKR CORE Smart Bike Trainer
  • Rear Leg
  • Front Leg
  • Nuts (x4)
  • Bolts (x4)
  • Hex Tool
  • 1.8mm Spacer
  • AC Power Adapter
  • Quick Release Skewer
  • Zwift Cog (pre-installed)
  • Zwift Click
SUPPORTED DEVICES
Bike Compatibility
BIKE COMPATIBILITY CHECK
Will my bike fit on the KICKR Core? Find out here.
Start
