KICKR CORE Smart Trainer
$449.99 $534.99
KICKR CORE offers a realistic, accurate, and quiet Zwifting experience. Purchase KICKR CORE with an optional 1-year Zwift membership for indoor cycling fun with serious fitness results.
  • +/- 2% power accuracy
  • Measures speed, distance, power, and cadence data
  • Includes your choice of a pre-installed cassette.
  • View More
  • Power Accuracy: +/- 2%
  • Maximum Power Output: 1800W
  • Connectivity: ANT+, ANT+ FE-C, Bluetooth
  • View More
Select a Cassette Option Cassette Guide
Purchase includes the option to add a 1-year membership to Zwift for €150, a €49.99 savings. Purchase includes the option to add a 1-year membership to Zwift for $150, a $49.99 savings. Purchase includes the option to add a 1-year membership to Zwift for £130, a £49.99 savings. Purchase includes the option to add a 1-year membership to Zwift for $190, a $59.99 savings. Purchase includes the option to add a 1-year membership to Zwift for $230, a $69.99 savings. Purchase includes the option to add a 1-year membership to Zwift for ¥18000, a ¥6000 savings. Membership requires Zwift account and auto-renews after 12 months at €199.99, $199.99, £179.99, $249.99, $299.99, ¥24000, unless cancelled.
Billing information required to redeem. Terms apply.
KICKR CORE Benefits
Optimized flywheel technology
KICKR CORE features a 12lb flywheel engineered to provide riders with the precise inertia needed to recreate an outdoor ride feel while riding an indoor bike trainer.
Flexible, easy set-up
KICKR CORE is compatible with 8, 9, 10, 11, and 12 speed cassettes, plus the Zwift Click and Cog, to align with your bike's groupset.
Ecosystem compatible
KICKR CORE seamlessly connects to the hardware devices and software platforms that make up the Wahoo indoor cycling ecosystem to give you endless ways to get fitter and faster through training indoors.
Designed to endure
Built from robust steel construction, the design and materials ensure stability and durability even during your most intense training sessions.
Your ride. Your way.
Choose the pre-installed cassette option that matches your bike and you'll be ready to ride.
KICKR CORE is compatible with 8, 9, 10, 11 and 12 speed cassettes, giving you the flexibility to add your preferred cassette to the smart bike trainer, so that you can fully mimic your outdoor groupset.
MAX GRADE SIMULATION
10% 12% 16% 20%
MAX POWER (WATTS)
1500w 1800w 2200w
KICKR CORE Features
KICKR TO THE CORE
CONTROLLED RESISTANCE
When connected to your smartphone, tablet, computer or GPS bike computer, KICKR CORE smart bike trainer automatically controls your resistance based on the software or route.
POWER, SPEED, DISTANCE and CADENCE
PROFESSIONAL GRADE DURABILITY
KICKR CORE Specs
TECH SPECS
  • Maximum Power Output: 1800 Watts
  • Product Weight: 40 lb / 18 kg
  • Drivetrain: Belt Drive
  • Power Accuracy: +/-2%
  • Connectivity: ANT+, ANT+ FE-C, and up to three Bluetooth Connections
  • Cassette: Not Included
  • KICKR CORE smart trainer gives you the option to install your own cassette or select a pre-installed cassette.
WHAT’S IN THE BOX?
  • KICKR CORE Smart Bike Trainer
  • Rear Leg
  • Front Leg
  • Nuts (x4)
  • Bolts (x4)
  • Hex Tool
  • AC Power Adapter
  • Quick Release Skewer
  • 1.8mm Cassette Spacer
SUPPORTED DEVICES
Bike compatibility
BIKE COMPATIBILITY CHECK
Start
