Free shipping on orders over $20!
Wahoo RPM Cadence Sensor
Wireless Bluetooth and ANT+ Cycling Cadence Sensor
More Views
SKU# WFPODCAD2
$39.99
Shop with 100% confidence
free shipping to the US over $20 / awesome customer service / no hassle returns within 30 days / 1 yr limited warranty / get help from a pro (a cycling/running/fitness-loving wahooligan!)
Wahoo RPM Cadence Sensor Overview
The Wahoo RPM cadence sensor is your sleek little solution for measuring cycling cadence data. It's wireless, magnet-less, lightweight, and easily mounts to your bike's crank arm or to your shoe. Bluetooth Smart and ANT+ dual band technology allows you to connect to and display data on both smartphones and GPS bike computers. Collecting cadence data has never been this easy.
Dual Band Technology
Wireless Connection
Sleek, Lightweight Design
It only weighs 7 grams!
Cadence Measurement
Provides accurate cadence data during your ride
Two Bike Mount Options
(1) mount with double sided 3M tape, or (2) use the silicone sleeve and mount with zip ties.
Shoe Mount Option
The RPM can be worn on your shoe for spin classes or use with multiple bikes
Visible Connection
Two LED lights show the sensor's device connection (blue) and cadence detection (red)
Replaceable Battery
No charging required! Operates on a coin cell battery for up to 1 years.
Universal Fit
RPM cadence sensor will fit with most bikes and frame sizes
Supported Devices
iPhone
iPhone 4S and newer
Android
Click here for compatible devices
iPad
iPad (3rd gen and newer), iPad Mini, iPad Air
iPod
iPod Touch (5th gen)
Specs
Physical Dimensions (LxWxH): 1.25" x.75" x 1"
Weight: 7 grams
Battery: CR2032
Battery Life: Up to 12 months
Water Rating: IPX7 (waterproof up to 5 ft)
Wireless Signal Strength Up to 10 feet
In the Box
RPM Cadence sensor
CR 2032 Battery (installed)
Rubber Mounting Option
Zipties
Shoe Mount Option
3M double sided tape
Quick Start Guide
Important Product Info Guide
Product Instructions
Click here for RPM instructions
Reviews
Wahoo RPM Cadence Sensor is rated 3.8 out of 5 by 104.
Rated 5 out of 5 by from Perfecto! Makes a big difference to train properly knowing your cadence in such a simple yet advanced small sensor.
Date published: 2017-04-17
Rated 1 out of 5 by from Disappointed: disconnects and drops out I bought this six months ago (along with Kickr and HRM). The other parts are great but the cadence sensor is almost useless. I never get a trouble free ride. At least one of the following will happen: takes several attempts to connect at start of ride; drops out after a few minutes or as soon as I spin over 100 rpm; apps show "connected" but with no reading; signal comes in and out but with obviously wrong readings.
Date published: 2017-03-24
Rated 2 out of 5 by from Wahoo kickr cadence sensor Doesn't seem to be accurate or responsive
Date published: 2017-03-20
Rated 5 out of 5 by from Stick and go! I purchased the Cadence counter to help me with my "at-home" spin classes; the apps I use often base their directions on cadence so I needed something to let me know how I was doing. I had the Cadence counter out of the box and in use within minutes. I also use the Wahoo Tickr HRM and it's so nice to be able to see both readouts from one (Wahoo) app. Great purchase! Highly recommend!
Date published: 2017-02-27
Rated 1 out of 5 by from Very Dissapointed I purchased the cadence sensor and cannot get it to pair with my apps. I have an iphone 7 and us Strava, Map My Ride and now also Wahoo. The phone indicates that the sensor is linked, but none of the apps will pair. I have tried all the suggestions at the Wahoo and Strava websites to no avail.
Rated 5 out of 5 by from Good sensor for spin! Got this a month ago to use for spin class, our bikes don't have any computers on them. I put the sensor in an extra foot pod case I had, and stuck it on the bottom strap of my shoe. It works fine flat, it doesn't need to be "vertical" as if it were attached to the crank arm. I put the app up on my phone, stick it in one of the two water bottle holders, and base my resistance off the RPMs. I wish there was a "quick" way to add on the speed sensor as well, trying to determine distance requires a degree in mathematics!
Date published: 2017-02-19
Rated 5 out of 5 by from Fast Delivery, easy install, instant setup Fast Delivery, easy install, instant setup... works perfectly
Date published: 2017-02-16
Rated 3 out of 5 by from Works great ... when it works I was excited to find this product to use on my new spin bike to track cadence. Out of the box I could not get it to work. Emailed support, and in addition to trying a new battery was given a list of things to try (restart my phone, etc.). The minute I put the new battery in, the flashing light appeared and I was set. (So why even insert the battery in the product? Either send without a battery or include it separately). I used it to spin twice in three days and it was great, I was stoked. Two days later and less than a week after replacing the original battery, I go to spin and the sensor isn't connecting. Try a new battery and we are back to the blinking light and it's ready for use. I have my sensor laying in two parts with the battery not installed in hopes of getting more than a week out of one battery, otherwise I'd be better off paying for a spin CLASS than replacing a battery every week. SERIOUSLY Wahoo, this product is on the verge of being SO GOOD but this battery thing has to be fixed. An on/off switch would be great. Instructions on removing the battery between uses (as much as pain that is?) or would 'forgetting the sensor' on the app work too? Not sure and I'm taking no chances but my excitement for this has waned with this battery issue we are ALL having. PLEASE FIX
Date published: 2017-02-02
  • y_2017, m_4, d_21, h_22
  • cp_1, bvpage1
  • co_hasreviews, tv_8, tr_96
  • loc_en_US, sid_WFPODCAD2, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 17.86ms
You may also be interested in the following product(s)
