$1,399.99
DUAL-ROLLER DESIGN |
Dual-roller design frees up the rear wheel to move naturally, providing an experience that feels more like riding outdoors while reducing tire slip, no matter how much power you put to the pedals. |
SAFETY TIRE GRIPPER |
The front safety tire gripper can accommodate tires up to 2.1" (53mm) to keep your bike upright and secure, making it easy to get on and off the bike while providing stability, even when sprinting. Check bike compatibility for more details. |
CONVENIENCE FOCUSED DESIGN |
KICKR ROLLR was designed from the ground up to minimize the pain points of setting up your bike on the trainer. No more fussing with thru axles or removing your rear wheel, simply adjust the wheel base, secure your bike and ride. |
POWER METER CONNECT |
Connect Wahoo POWRLINK ZERO power pedals or other ANT+ power meters to KICKR ROLLR to get the benefits of training with power. ROLLR provides power readings to within +/-1% accuracy of the power meter, allowing you to train with the same precision, indoors and outdoors. |
CONTROLLED RESISTANCE |
When connected to an external power meter, KICKR ROLLR provides controlled resistance in level, ERG and simulated modes. Without a connected power meter, KICKR ROLLR delivers consistent resistance and broadcasts speed metrics. |
QUICK-ADJUST WHEELBASE CLAMP |
Quickly transition from outdoor rides to indoor rides. Simply open the quick-adjust wheelbase clamp and adjust the wheel chocks to match your bike's wheelbase: ideal for riders with multiple bikes or households with multiple riders. |
MANUAL MODE |
No power meter? No problem. Manual mode allows KICKR ROLLR to operate like a conventional set of rollers when not connected to a power source, making it ideal for pre-event warmup. |
OPTIMIZED FLYWHEEL TECHNOLOGY |
KICKR ROLLR features a 10.5lb flywheel that when combined with the dual-roller technology provides riders with the precise inertia necessary to replicate the feeling of riding on the road. |
REALISTIC RIDE FEEL |
KICKR ROLLR frees the rear wheel to deliver an ultra-smooth, natural ride feel. |
EASY APP SET-UP |
Our simple and intuitive Wahoo Fitness app offers guided instructions on how to set-up the KICKR ROLLR and pair your 3rd party apps and sensors to fine tune your ride. |
DISC BRAKE CLEARANCE |
The unique design of KICKR ROLLR allows it to accommodate a wide range of tire sizes, frames, and brake configurations. |
ANT+, ANT+ FE-C AND BLUETOOTH CONNECTIVITY |
Bluetooth and ANT+ capabilities allow it to connect to both smartphones and GPS devices simultaneously or separately. An ANT+ FE-C connection allows the KICKR ROLLR to be controlled from any FE-C enabled device or application. |
LED INDICATOR LIGHTS |
Visual confirmation that KICKR ROLLR is powered, connected and transmitting via Bluetooth and / or ANT+. Blue LED represents the Bluetooth connection between the ROLLR and the controlling app. A new RED LED represents the ROLLR’s connection to the power meter. |
MEASURES SPEED, DISTANCE, AND POWER |
Get speed and distance from the KICKR ROLLR without additional sensors. Power and cadence metrics are available when combining with POWRLINK ZERO or other compatible power meters. |
KICKR HEADWIND COMPATIBLE |
KICKR HEADWIND brings innovative climate control to your indoor training experience. Pair to KICKR ROLLR and as your speed or heart rate increases, so will the fan speed. |
ELEMNT BIKE COMPUTER COMPATIBLE |
Connect the KICKR ROLLR to any ELEMNT Bike Computer to relive rides or perform planned workouts. |
THIRD PARTY APP COMPATIBILITY |
Works with popular training apps, including SYSTM, Zwift, and TrainerRoad. For more details on which apps are compatible with the KICKR ROLLR, download our in-depth KICKR app comparison chart. |
THIRD PARTY POWER METER SUPPORT |
Compatible with Wahoo POWRLINK ZERO and most third-party power ANT+ meters. |
+/- 1% POWER ACCURACY |
Lab tested accuracy that provides a precise power measurement for all training efforts. |
LEFT POWER |
With a single-sided power sensor, your left side power is tracked and doubled to estimate total power output no matter where you are crushing watts. |
CADENCE |
With its internal gyroscope, POWRLINK ZERO reports out cadence data to help you identify your sweet spot effort and power output. |
EASY APP SET-UP |
Our simple and intuitive Wahoo Fitness app offers guided instructions on how to install POWRLINK ZEROs on any bike, calibrate the pedals for accuracy, and perform firmware updates. |
WAHOO ECOSYSTEM COMPATIBLE |
Pair POWRLINK ZEROs power meter pedals with the rest of the Wahoo Ecosystem for the most connected training experience. Track your metrics outdoors on an ELEMNT GPS Device or control indoors on a KICKR Smart Trainer for consistent data anywhere, anytime. |
DUAL-BAND ANT+ AND BLUETOOTH TECHNOLOGY |
POWRLINK ZERO can simultaneously connect to three Bluetooth devices while broadcasting to an unlimited number of ANT+ devices. |
DUAL-SIDED ENTRY |
POWRLINK ZERO is built on on the dual-sided entry SPEEDPLAY Pedal System, which maximizes power transfer by putting your foot closer to the spindle. No more fumbling, fussing or kicking your pedal over; leverage a powerful take off when the light turns green and clip in with ease. |
ENHANCED WALKABILITY |
The slim profile cleat and rubber texture create enhanced stability when walking in your road shoes off the bike. |
INTEGRATED PROFILE |
POWRLINK ZERO and the SPEEDPLAY Standard Tension Cleat create a secure connection and a streamlined profile. The two form a seamless integration that aids power transfer and increases aerodynamics. |
3-AXIS ADJUSTABILITY |
The Standard Tension Cleat can be positioned on the bottom of the shoe and adjusted fore-aft, left-right and rotationally, allowing between 0-15 degrees of float. |
ROTATIONAL FREE FLOAT |
POWRLINK ZERO power meter pedals provide up to 15 degrees of float, allowing the heel to pivot around the center of the pedal. This range of motion in the foot, lower leg and knee increases comfort and enhances pedal efficiency. |
SUPERIOR CORNERING CLEARANCE |
We've adapted the best-in-class corner clearance of SPEEDPLAY Advanced Pedal System into POWRLINK ZERO. This pedal and cleat integration allows for a large degree of lean on the bike when riding tight corners. Pedal with confidence knowing your pedal won't strike the ground and leave the competition in the dust. |
EXCEPTIONAL DURABILITY |
POWRLINK ZERO pedals offer uncompromised durability and minimal maintenance thanks to their stainless steel construction and triple-sealed bearing system. |
TEMPERATURE COMPENSATION |
POWRLINK ZERO is tested and proven to provide accurate power data across changing temperatures that you are sure to encounter while riding. |
RECHARGEABLE BATTERY |
Powered by a rechargeable lithium battery, POWRLINK ZERO power pedals have a battery life up to 75 hours. |
STANDARD TENSION CLEAT |
POWRLINK ZERO pedals include a set of Standard Tension Cleats and cleat surrounds for an aerodynamic profile and walkable system. |
EASY TENSION CLEAT |
Looking for even easier unclipping? POWRLINK ZERO is compatible with our Easy Tension Cleat, which can be purchased separately. |
Additional Tools Required for Assembly: #1 and #2 Philips Head Screwdriver and 8mm Allen Wrench
California residents: See the California Proposition 65 WARNING
KICKR ROLLR combines the convenient training experience and natural ride feel that only rollers can provide with the performance features and connectivity of a smart trainer. Featuring a dual-roller design, app controlled resistance, enhanced safety features, and adjustability that makes moving between multiple bikes a snap. Connect ROLLR to POWRLINK ZERO power meter for an enhanced training experience, delivering precise power data to help you maximize your training, indoors or outdoors.
