Overview Features Reviews
ELEMNT BOLT GPS Bike Computer Bundle
$349.99
More Views
Save $30 on this Cycling Bundle with an ELEMNT BOLT Bike Computer, TICKR Heart Rate Monitor, RPM Speed Sensor, and RPM Cadence Sensor
SKU# WFCC3B
$349.99
  • 30 Day, No Hassle Returns
  • 1 Year Limited Warranty
Reviews
Product Overview
Get everything you need to boost your cycling performance all at once! The ELEMNT BOLT features a patent pending design that integrates the bike computer and mount, resulting in a CFD tested, highly aerodynamic system built to be on the front of your bicycle. Not to mention, it's super easy to set-up and customize with the free companion app and features dual-band technology, wireless connection & uploads, pre-loaded global maps and routes, and so much more. The TICKR heart rate monitor, RPM Speed sensor and RPM Cadence sensor pair seamlessly with the ELEMNT, so that you can get live and accurate performance metrics.
BONUS! When you register your ELEMNT BOLT in the Companion app, you'll receive these awesome offers from our partners:
The ELEMNT BOLT is the most integrated GPS bike computer on the market with a full list of compatible hardware and smartphone apps.
ELEMNT BOLT FEATURES
Discover all the nitty gritty details about the BOLT GPS bike computer
TICKR FEATURES
Discover all the nitty gritty details about the TICKR heart rate monitor
RPM SPEED FEATURES
Discover all the nitty gritty details about the RPM speed sensor
RPM CADENCE FEATURES
Discover all the nitty gritty details about the RPM cadence sensor
Includes Mounts for ELEMNT BOLT bike computer and RPM Sensors
ELEMNT BOLT Two sturdy and secure mount options - an integrated out-front mount and stem mount. RPM Cadence comes with a crank and shoe mount. RPM speed comes with a hub mount.
Click here for ELEMNT BOLT instructions
Specs
ELEMNT BOLT Specs
Physical Dimensions: 2.9"" x 1.8"" x 0.87"" (74.6mm x 47.3mm x 22.1mm)
Display Size: 2.2"" (56mm)
Weight: 2.2 oz
Battery: USB rechargeable
Battery Life: 15 hours
Waterproof Rating: IPX7 (waterproof up to 5 ft)
Supported Satellites: GPS, GLONASS, BEIDOU Galileo, and QZSS
Operating Temperature: -4°F to 122°F / -20°C to 50°C
TICKR Specs
Physical Dimensions (LxWxH): 2.75" x .5" x 1.5"
Weight: 8.5 grams (without strap)
Battery: CR2032
Battery Life: Up to 12 months
Sweatproof: Yes (hand washable strap)
Water Rating: IPX7 (waterproof up to 5 ft)
Strap Length: Adjustable from 24" to 48" (stretched)
RPM Cadence Specs
Physical Dimensions (LxWxH): 1.25" x.75" x 1"
Weight: 7 grams
Battery: CR2032
Wireless Signal Strength: Up to 10 feet
ELEMNT BOLT GPS Bike Computer Bundle is rated 4.6 out of 5 by 135.
Rated 5 out of 5 by from More Accurate than Garmin (so far) I bought this bundle at the same time that my wife got a garmin 520 bundle, she’s had dropouts and issues getting accurate speed/distance data but I’ve had none so far (3 weeks in). Everything was easy to set up and integrate with apps and my indoor trainer. The Computer did come with a screen defect but Wahoo support was very helpful and covered the return/swap.
Date published: 2018-10-15
Rated 4 out of 5 by from Great for planned rides I bought the bundle a few weeks ago and at first it has been great as I only used it for tracking my rides and navigating pre-planned routes. But then I took it with me to navigate through the city and I was really disappointed with the Take Me To feature. It didn't find the adress that I wanted to go to and I couldn't even drop a pin to tell the unit where to go that way. So in conclusion - I am satisfied with my purchase, because I mostly use the Bolt to track my pre-planned rides, but it would be great if it could be used for instant navigation.
Date published: 2018-10-11
Rated 5 out of 5 by from A great replacement for the [email protected] When my 820’s screen failed after just 2 years of use...I decided it was time to try a Wahoo. I have never been happier! The battery life is so much better than any other bike computer that I have ever had. The display is clear and easy to read in all sorts of lighting conditions. I really like the fact that you can set everything up on a smartphone with no need for a computer or cables.
Date published: 2018-10-08
Rated 5 out of 5 by from Easy to set up Best bike computer ever. I even bought one for my wife. Love how easy it is to set up and rearrange the screens. Plus there are some many different options for the screens
Date published: 2018-10-02
Rated 5 out of 5 by from Love riding with this device! I can do everything I imagined I could do and more. First of all, the basics (data, navigation, workouts) work really well, set up is super simple and the interface is intuitive. Next, all the connected apps and integration were a nice surprise. I am now enjoying discovering routes and workouts through other apps and uploading them.
Date published: 2018-10-01
Rated 5 out of 5 by from The Iphone of bike computers Coming from the Garmin 510 is like moving from and Android to an Apple product.
Date published: 2018-09-29
Rated 5 out of 5 by from Great easy to use product This is my first bike computer. I found the fitting and setup very easy using the companion app. It was well worth the price compared to other offerings on the market and has all of the functionality i require.
Rated 5 out of 5 by from Intuitive, reliable, and user-friendly. I labored over the decision between the Element Bolt and the Garmin Edge 820 for about a month prior to a trip to the French Alps. I have no doubt that I made the correct decision. Two of my friends had new Garmins. They struggled with downloading routes, Acquiring a GPS signal, and customizing screens. The Bolt functioned flawlessly, and it was simple and intuitive. I summitted the learning curve in less than five minutes. The two purported benefits of the Garmin over the Bolt are its touch screen and the color screen. I missed neither. I wear sunglasses almost all of the time when I ride, and these dull the color graphics anyway. The black and white graphics on the Bolt are crisp and easy to see while riding with sunglasses, and the zoom feature (available on all screens) is great and easy to use. Colorgraphics sound great and look cool while sitting inside, but I didn’t miss the color single bit. Furthermore, I don’t ride for pretty pictures on my computer screen, I ride for the beauty around me. I was in search of a functional intuitive bike computer with excellent features, and I found it in the Bolt. My friends corroborated what others have reported about the Garmin touchscreen not working reliably. The buttons on the bolt work great; however, I have largely stopped using them because the Bolt integrates so well with my DI-2 electronic shifters. I now switch between screens and zoom in and out using the auxiliary buttons on my DI-2 shifters. The Companion application makes customizing screens a joy. Looking at the seemingly crude graphics on the Bolt navigation screen initially spooked me, but the system is reliable, and I did not feel like I was playing computer “pong“ in 1978 when I was using it. Colorgraphics sound great and look cool while sitting inside, but I didn’t
  • y_2018, m_10, d_21, h_17
  • cp_1, bvpage1
  • co_hasreviews, tv_6, tr_129
  • loc_en_US, sid_WFCC3B, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 20.92ms
Product Overview
TICKR FEATURES
RPM SPEED FEATURES
Specs
ELEMNT BOLT Specs
Weight: 2.2 oz
TICKR Specs
Battery: CR2032
RPM Cadence Specs
Weight: 7 grams
Battery: CR2032
Reviews
