Overview Reviews
KICKR 12x142 Thru Axle Adapter
$29.99
More Views
For the Wahoo KICKR 2014 and 2016 editions
SKU# WFKICKR142
$29.99
  • 30 Day, No Hassle Returns
  • 1 Year Limited Warranty
Reviews
Product Overview
This kit comes with everything you need to mount most 12x142 thru-axle bikes on your KICKR indoor trainer. It will work only with the 2014 and 2016 editions of the KICKR. It includes the following:
  • Threaded Axle Spacer
  • Hub Width Adapter
  • Conical Axle Adapter
  • Flat Axle Adapter
  • XL Quick Release Skewer
  • Extended Quick Release Nut
Note: The KICKR is not compatible with the thru-axle itself; instead, we use this adapter kit to secure the bike in place. Please watch the installation video or read the adapter instructions before attempting to install yourself. This is for 12x142 bikes only. Not compatible with 12x135, 12x148, or any other thru-axle system. If you have any questions, don't hesitate to contact us!
Click here for Adapter instructions
KICKR 12x142 Thru Axle Adapter is rated 4.3 out of 5 by 24.
Rated 3 out of 5 by from Worked... but I had to make it work I guess for some bikes the adapters don't fit correctly and you'll have to sand it down a few millimeters to have your bike snug on the brake side. If you don't the bike will not be stable enough to use on the trainer.
Date published: 2018-03-21
Rated 2 out of 5 by from not for everything End caps for left drop out are too wide for my scott addict disc, the bike can't be secured properly.
Date published: 2018-03-07
Rated 5 out of 5 by from works well I bought this 12x142 thru axle adaptor for my 1st generation KICKR so I could use me new bike that has thru axles and disc brakes. (2017 Venge ViAS Pro Disc) I simply watched the video regarding replacement of the quick release axle with the thru axle adaptor, super simple and quick to complete and has worked flawlessly!
Date published: 2018-02-23
Rated 5 out of 5 by from Works on a 2018 Roubaix Installed fairly easy. Seems to work just fine with a 2018 Specialized Roubaix Di2.
Date published: 2018-02-20
Rated 5 out of 5 by from Perfect fit for the Wahoo Snap trainer I received a Wahoo Snap for Christmas, turns out I needed a Thru Axle adapter because my Cyclops didn't work. The Wahoo Thru Axle is a perfect fit. One issue is depending on your bike it might get close to the frame. I have a 2017 BMC Roadmachine 02 carbon bike and I had to put a small spacer in the left side of the trainer so that it gave some clearance from my frame. Otherwise it is a perfect fit.
Date published: 2018-01-15
Rated 5 out of 5 by from Perfect Fit! I've had this for about 3 weeks now and I ride the trainer about 4-5 time a week (45 minutes - 1 hour 30 minutes) and have had no issues with it. I'm using it on the Wahoo Kickr and it's a perfect fit! Easy to use!
Date published: 2018-01-11
Rated 5 out of 5 by from Great product! Have had it for a week now works great and the ease of converting was simple and easy.
Date published: 2018-01-04
Rated 4 out of 5 by from Works well after fixing it.... Bought this for my 2018 Giant Propel Advanced Pro Disc. Had to file down the non-drive side spacer about 3mm to get rid of side-to-side play on the non-drive side dropout. Now it works just fine.
Date published: 2017-12-01
  • y_2018, m_7, d_20, h_4
  • cp_1, bvpage1
  • co_hasreviews, tv_2, tr_22
  • loc_en_US, sid_WFKICKR142, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 14.86ms
Product Overview
  • Hub Width Adapter
  • Flat Axle Adapter
For more info, see Faq
Specs
Reviews
