Overview Reviews
CAMPAGNOLO FREEHUB
$69.99
CAMPAGNOLO FREEHUB
More Views
CAMPAGNOLO FREEHUB
For the 2014 and 2016 Edition KICKR Smart Trainer
SKU# WFKICKRCAM
$69.99
  • 30 Day, No Hassle Returns
  • 1 Year Limited Warranty
Reviews
Product Overview
This freehub makes your 2014 or 2016 Edition Wahoo KICKR indoor trainer compatible with Campagnolo 9, 10, and 11 speed cassettes. It will ONLY work with these editions of the KICKR and is not compatible with any newer edition.
Note: Installation is required! Please view our support site for Campy Adapter instructions. Campagnolo Cassette and Lock Ring are not included. Please view the installation video below to insure you have all of the proper tools before purchasing. If you do not want to perform the installation yourself, your local bike shop will have the tools and the know-how to get you up and running with Campy! The black, rubber dust seal mentioned in the video is no longer in use. Please install the Campagnolo Freehub without this dust seal.
CAMPAGNOLO FREEHUB FOR KICKR Smart Trainer is rated 3.7 out of 5 by 15.
Rated 5 out of 5 by from Easy installation, works great The video shows how you can swap between Shimano and Campagnola free hubs without removing the cassettes making bike swapping easy.
Date published: 2017-12-22
Rated 5 out of 5 by from Great Upgrade for Campy Users While Campy 11 speed cassettes are supposedly compatible with Shimano 11 speeds, I found that the Shimano cassette that came with my Kickr ran a little rough in a couple of gears with my Campy 11 speed derailleur. The Campy freehub conversion was easy to install and runs much smoother. I highly recommend this for Campy fans.
Date published: 2017-12-20
Rated 5 out of 5 by from Campagnolo Freehub Easy peasy. Removed the shimano free hub, one bolt and a quick turn it was off. Greased the campagnolo free hub, installed it and installed the bolt to 6nm. Done. Campagnolo Chorus 11 speed cassette mounted and torqued. Perfect fit and easy to install. No more grinding and perfect shifts.
Date published: 2017-12-15
Rated 5 out of 5 by from Easy easy to mount Now i can leave my cassete and freehub mounted on my back wheel, so it's no problem riding outdoirs
Date published: 2017-05-25
Rated 5 out of 5 by from Single word CAMPAGNOLO What can I say .. It worksBut spacing is off.. my rear derailleur rubs when in my largest cog.. Campaganola chorus11 speed Cannondale CADD10
Date published: 2017-05-09
Rated 5 out of 5 by from Gotta have it if you ride campy If campy is your main mode then this freehub is what you will need. To bad it's not an option when purchasing your Kickr.
Date published: 2016-10-25
Rated 5 out of 5 by from Works Well I installed the hub and then installed the Campy 11 cassette off my bike. Works well. No problems.
Date published: 2015-12-29
Rated 5 out of 5 by from Campy Hub Installed easily without any issues. Shifts and operates the same as when on the road.
Date published: 2015-12-23
  • y_2019, m_2, d_16, h_15
  • cp_1, bvpage1
  • co_hasreviews, tv_1, tr_14
  • loc_en_US, sid_WFKICKRCAM, prod, sort_[SortEntry(order=RATING, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 10.11ms
Product Overview
Specs
Reviews
