Overview Features Reviews
ELEMNT BOLT GPS Bike Computer Bundle
$349.99
More Views
Save $30 on this Cycling Bundle with an ELEMNT BOLT Bike Computer, TICKR Heart Rate Monitor, RPM Speed Sensor, and RPM Cadence Sensor
SKU# WFCC3B
$349.99
  • 30 Day, No Hassle Returns
  • 1 Year Limited Warranty
Reviews
Product Overview
Get everything you need to boost your cycling performance all at once! The ELEMNT BOLT features a patent pending design that integrates the bike computer and mount, resulting in a CFD tested, highly aerodynamic system built to be on the front of your bicycle. Not to mention, it's super easy to set-up and customize with the free companion app and features dual-band technology, wireless connection & uploads, pre-loaded global maps and routes, and so much more. The TICKR heart rate monitor, RPM Speed sensor and RPM Cadence sensor pair seamlessly with the ELEMNT, so that you can get live and accurate performance metrics.
BONUS! When you register your ELEMNT BOLT in the Companion app, you'll receive these awesome offers from our partners:
The ELEMNT BOLT is the most integrated GPS bike computer on the market with a full list of compatible hardware and smartphone apps.
ELEMNT BOLT FEATURES
Discover all the nitty gritty details about the BOLT GPS bike computer
TICKR FEATURES
Discover all the nitty gritty details about the TICKR heart rate monitor
RPM SPEED FEATURES
Discover all the nitty gritty details about the RPM speed sensor
RPM CADENCE FEATURES
Discover all the nitty gritty details about the RPM cadence sensor
Includes Mounts for ELEMNT BOLT bike computer and RPM Sensors
ELEMNT BOLT Two sturdy and secure mount options - an integrated out-front mount and stem mount. RPM Cadence comes with a crank and shoe mount. RPM speed comes with a hub mount.
Click here for ELEMNT BOLT instructions
Specs
ELEMNT BOLT Specs
Physical Dimensions: 2.9"" x 1.8"" x 0.87"" (74.6mm x 47.3mm x 22.1mm)
Display Size: 2.2"" (56mm)
Weight: 2.2 oz
Battery: USB rechargeable
Battery Life: 15 hours
Waterproof Rating: IPX7 (waterproof up to 5 ft)
Supported Satellites: GPS, GLONASS, BEIDOU Galileo, and QZSS
Operating Temperature: -4°F to 122°F / -20°C to 50°C
TICKR Specs
Physical Dimensions (LxWxH): 2.75" x .5" x 1.5"
Weight: 8.5 grams (without strap)
Battery: CR2032
Battery Life: Up to 12 months
Sweatproof: Yes (hand washable strap)
Water Rating: IPX7 (waterproof up to 5 ft)
Strap Length: Adjustable from 24" to 48" (stretched)
RPM Cadence Specs
Physical Dimensions (LxWxH): 1.25" x.75" x 1"
Weight: 7 grams
Battery: CR2032
Wireless Signal Strength: Up to 10 feet
ELEMNT BOLT GPS Bike Computer Bundle is rated 4.5 out of 5 by 63.
Rated 4 out of 5 by from Features great, documentation lacking Product performs as stated but no documentation included. Some links from web site lead to older products, not current.
Date published: 2018-01-20
Rated 5 out of 5 by from Outstanding, very easy to use! This is exactly what I needed, easy to set up and use. Mapping and turn by turn directions are great.
Date published: 2018-01-17
Rated 5 out of 5 by from Garmin beater I’ve owned the Elemnt bolt along with the cadence speed and HR monitors for just short of a month now. So far all the kit has exceeded expectations. In comparison to the garmin devices I’ve previoudly owned, the bolt is far simpler to use and set up both indoors and outside. The battery life on the bolt is in a different league to the garmin. I’ve used it for over 7 hours and it still has 40% battery life left. This is with Back light and LED’s operational. The return to buttons instead of a touch screen is refreshing as it works and is less frustrating especially whilst wearing gloves. I haven’t used the mapping yet but if this operates in the same manner as everything else I foresee no problems. Well done wahoo for producing worthy competition for Garmin. I’ll be honest I was sceptical but no More. Buy one you won’t regret it.
Date published: 2018-01-06
Rated 4 out of 5 by from great! with room for improvement I purchased the Elemnt bolt bundle. Previously I had... well, you know it! I am very happy with my new unit, connectivity is awesome, battery is incredible, so far it never crashed like it happened many times with... well, you know it! Few things could be improved: - Maps: I understand the unit has its limitations in this department (b&w screen and size), but elevation curves would be appreciated, especially when going offroad - Sensors: speed sensor is ok, a little on the bulky side. Cadence sensor: if I had known better I would not have bought it! Somewhere I heard or read the sensor fit almost 99% of bike frames, unfortunately it does not fit with my 2017 Emonda SL, go figure! The rubber casing makes the sensor too bulky for the space between crancks and frame, zip ties are an awful solution, the only way to install it w/o problems is to use the 3M sticker, but I dislike very much the solution, it feels very unpractical for many reasons (there is no need to mention them to a community of cyclists). Maybe a sensor connected directly with a system of O-rings would be smart...? Average ascent speed (VAM in italian): I understand there are some 170 measurements to choose from, but this needs more. Since this parameter is always a bit tricky to measure with gps, it would be veeery nice to have the possibility to choose between istantaneous, 5 sec averge and 30 sec average measurements to smooth/stabilize readings.
Date published: 2017-12-30
Rated 5 out of 5 by from Excellent computer and easy to setup I’ve had this a week. It’s very intuitive. I love being able to see my training details. It’s a perfect size. I can see text messages and callers from my phone while riding too.
Date published: 2017-12-29
Rated 5 out of 5 by from Great value and user friendly. The bundle is a great value over other Garmin competitors. The Bolt and its companion app are both very user friendly. Only criticism is that the display is smaller than anticipated; not too much of a problem as you can zoom in and out of the page you're on.
Rated 5 out of 5 by from Elemnt Bolt Bundle My first bike computer having used Strava on my smartphone for the last few years. Decided to get the Bolt after my pal recommended it as ideal as a training aid to help improve my riding. So far I've only used the computer but absolutely ideal - easy to use and read while riding. So far very impressed and glad I purchased.
Date published: 2017-12-27
Rated 5 out of 5 by from First time!! This is my first serious bike computer and I am very satisfied. Is very simple to set up and the basic features works as expected. The only thing is that the maps may not be updated for Colombia, but I am sure that this can be updated soon.
Date published: 2017-12-24
  • y_2018, m_1, d_23, h_11
  • bvseo_bulk, prod_bvrr, vn_bulk_2.0.6
  • cp_1, bvpage1
  • co_hasreviews, tv_1, tr_62
  • loc_en_US, sid_WFCC3B, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 85.96ms
Product Overview
TICKR FEATURES
RPM SPEED FEATURES
For more info, see Faq
Specs
ELEMNT BOLT Specs
Weight: 2.2 oz
TICKR Specs
Battery: CR2032
RPM Cadence Specs
Weight: 7 grams
Battery: CR2032
Reviews
