Stem Mount for ELEMNT Bike Computers
$14.99
More Views
Out of Stock
SKU# WFCC1M2
$14.99
  • 30 Day, No Hassle Returns
  • 1 Year Limited Warranty
Reviews
Product Overview
Our stem mount for Wahoo ELEMNT GPS bike computers is made of lightweight, durable plastic and is a great solution for cyclists who prefer to keep their computer on top of the stem.
  • Fits any stem
  • Weight: 0.2oz
  • Works with ELEMNT, ELEMNT BOLT, and ELEMNT MINI (Note: BOLT loses aerodynamic advantage with this mount)
  • Includes four (4) zip ties for mounting
Stem Mount for ELEMNT Bike Computers is rated 2.7 out of 5 by 19.
Rated 3 out of 5 by from A small fortune for this product. This mounts easily with the zip ties provided. It is easy to use and holds the computer firmly. It costs a lot of money for an item that is easily broken in a crash. This is a 'consumable accessory' and as such it should be cheaper or you should be able to buy multiple units in one order at a discount. How about even putting a couple of spares in the box with the computer?
Date published: 2018-10-03
Rated 2 out of 5 by from Mount needs work Zip tie is not a good solution. Rubber o-rings like Garmin uses on their mount are much better. Ended up cutting 2mm from one side of a spare Garmin mount, works better.
Date published: 2018-09-12
Rated 3 out of 5 by from Must have if the aero mount does not fit the hande Works as expected but very low value for the money
Date published: 2018-07-17
Rated 2 out of 5 by from Needs work Doesn't "fit any stem" as advertised. My Canyon CX and MTB both have a square, not round, stem, so it doesn't fit without taking off the rubber which then makes it less secure. I had to move it over to the handlebars. Who uses zip ties anymore? You can never get them tight enough.
Date published: 2018-05-17
Rated 1 out of 5 by from Zip Ties = Thumbs Down Agree with other reviews. The zip tie attachment is awful. Garmin rubber band design is way better! Also, should be m more that $6.
Date published: 2018-05-06
Rated 2 out of 5 by from Way overpriced Works really well, I use it on my second bike. However, the price is so, so high, especially with postage. Sort it out, Wahoo!
Date published: 2018-05-01
Rated 3 out of 5 by from Works but there are better designs It does the job but it's expensive for small piece of plastic. I also semi-regularly swap between different bikes so the cable ties are a pain. For all their faults, the Garmin version with the rubber bands is a much better solution.
Date published: 2018-01-09
Rated 2 out of 5 by from Zipp Tie Its functional but the zip ties are a pain. Would prefer a rbber band solution.
Date published: 2018-01-04
  • y_2018, m_10, d_21, h_17
  • cp_1, bvpage1
  • co_hasreviews, tv_2, tr_17
  • loc_en_US, sid_WFCC1M2, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 22.35ms
Product Overview
  • Fits any stem
  • Weight: 0.2oz
Specs
Reviews
