Overview Reviews
Out Front Mount for ELEMNT Bike Computers
$19.99
More Views
SKU# WFCC1M1
$19.99
  • 30 Day, No Hassle Returns
  • 1 Year Limited Warranty
Reviews
Product Overview
Our out front mount for Wahoo ELEMNT GPS bike computers is made from lightweight, durable plastic and is ideal for keeping your eyes on your data and the road.
  • Fits 31.8mm round bars
  • Weight: 0.7oz
  • Works with ELEMNT, ELEMNT BOLT, and ELEMNT MINI (Note: BOLT will lose aerodynamic advantage with this mount).
Out Front Mount for ELEMNT Bike Computers is rated 4.3 out of 5 by 17.
Rated 5 out of 5 by from Puts the Bolt right where you need it Easy to install and holds the bolt firmly in place.
Date published: 2018-07-17
Rated 5 out of 5 by from Does what it says on the tin Holds my ELEMNT in place at a much lower cost than many of the aftermarket options. Highly recommend.
Date published: 2018-06-18
Rated 4 out of 5 by from Exactly what I needed I looked at a few mounts and I went with the Wahoo Out Front Mount because of it’s clean look.Some of the others Quality construction and sturdy.
Date published: 2018-02-18
Rated 4 out of 5 by from Good product - but expensive It's a bracket - it's well-engineered and good quality; but almost $50? Seems darned expensive for what it is.
Date published: 2018-01-25
Rated 5 out of 5 by from It's a mount! It's hard to write a review on something that is simple and does what it should. I will say this, other brands of the same size computer want you to use a little tether cord in case it comes loose. That notion alarms me. The elemnt mount is rock solid. Through a lot of road and harsh gravel riding it has never so much as twitched loose. It works like it should. I always feel confident it will keep the computer safe.
Date published: 2018-01-19
Rated 4 out of 5 by from Pretty much exactly what it says it is It's an extra out in front mount, same as the the kind that comes stock on the regular elemnt, no surprises, made of plastic, rubber grip for the bar wish it was either one penny more expensive so it would qualify for free shipping or five bucks cheaper, because 20 plus shipping seems a bit much for what it is, mounts solid, hinge is kind of annoying for the positioning of it, but easy enough to get in place
Date published: 2017-11-28
Rated 1 out of 5 by from Nice but...loses the computer too easily. It is much too easy to lose your expensive device! The resistance to rotate the computer needs to be increased. The mount comes with a screw to permanently lock the device however this is not realistic or easy to use if you want to remove the computer for charging, or using on another bike. The majority of friends who have these have lost their device. :(
Date published: 2017-10-17
Rated 4 out of 5 by from can be better i bought 2 additional front mounts for my other bikes. It would be great if it comes with some additional rubber shim that would help to clamp on some smaller size handlebars.
Date published: 2017-08-28
  • y_2018, m_7, d_20, h_4
  • cp_1, bvpage1
  • co_hasreviews, tv_2, tr_15
  • loc_en_US, sid_WFCC1M1, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 11.54ms
Product Overview
  • Weight: 0.7oz
For more info, see Faq
Specs
Reviews
