Overview Reviews
Aerobar/TT Mount for ELEMNT Bike Computers
$14.99
More Views
SKU# WFCC1M3
$14.99
  • 30 Day, No Hassle Returns
  • 1 Year Limited Warranty
Reviews
Product Overview
Our aerobar/TT mount for Wahoo ELEMNT GPS bike computers is made of lightweight, durable plastic and is the ideal viewing position during your triathlon or time trial.
  • Fits 22.2mm aero bar extensions
  • Weight: 0.3oz
  • Works with ELEMNT, ELEMNT BOLT, and ELEMNT MINI (Note: BOLT loses aerodynamic advantage with this mount)
  • Aerobar/TT Mount for ELEMNT Bike Computers is rated 3.2 out of 5 by 12.
    Rated 2 out of 5 by from BEWARE! Not compatible with ALL aero bars This mount is just slightly too small to mount my Syntace aerobar. Quite disappointed by this.
    Date published: 2018-07-03
    Rated 4 out of 5 by from Works perfect but becareful! Bought this for TT bike and it works great with only one caution. Do not overtighten the Allen screw that holds in place as it will pull the nut out of the plastic on the other side of the mount. Used a little epoxy am definitely pressed back into place and just snugged it up and it works great! Mane a little more robust nut on the other side and a washer would prevent this problem, but having the element there for use during ITT is worth all the effort !! Great product!
    Date published: 2018-06-12
    Rated 2 out of 5 by from Needs work It works....... but 1. this should come with a rubber strip to stop the mount from slipping. 2. The curved plastic should curve up, not down to allow the computer to 'recess' into the aero bars. After all, this would be more aerodynamic IMHO. 3. Cheap plastic. Seems like it would break and is not durable.
    Date published: 2018-06-07
    Rated 4 out of 5 by from Does the job Shame the interface can't be common to Garmin as I've had to replace the mounts on several bikes. This one does the job, though you may want to add a wrap of friction tape under the clamp if your aero bars are on the smaller side of the range. Also, too bad that the aero interface with the Bolt wasn't retained for the application where customers obviously will care about aero consideration!
    Date published: 2018-05-01
    Rated 4 out of 5 by from Easy to mount A little hard to get really tight so I cut a small cube of rubber and put it in the mount, wow worked great. The issue is not all the TT bars are the same size, easy fix!
    Date published: 2017-10-22
    Rated 1 out of 5 by from Cheaply Made The mount is cheaply made and does not grab or lock well enough to keep the mount from moving on my TT bars. I tried to tighten it down and the lock bolt for the screw came right out of the plastic mount. After getting it back in, I re-tightened it just enough to stay on and then mounted it with black electrical tape. This needs to be improved so that you can get a more secure fit. I also tried added a thin piece of rubber to the mount ring to help make it lock snuggly, but the screw isn't long enough so tape was the best option.
    Date published: 2017-08-23
    Rated 2 out of 5 by from disappointed circumference to install around oa normal aero bar is too small. result is the super short screw isn't long enough to bring together the two sides of the circle. i have a normal aero bar and find the hours i have spent getting the screw to thread to the other side, or to find a longer screw at home depot ridiculous considering i paid $15 for a small piece of plastic. a longer screw would be great. right now i have an overpriced mount that is worthless because the tiny screw is too short.
    Date published: 2017-07-02
    Rated 4 out of 5 by from Nice little gem The mount does what you want to do it. No surprises, usual Wahoo quality. Why no 5*? Because there are 2 points of improvement in my opinion: 1) I think it should be 1-2 cm wider, it's now just a bit too tight towards the aerobar. My arm sometimes hits the ELEMNT Bolt while cycling. But, (un)tying the computer is no problem however. Maybe it's just my specific setup. 2) If you install it right out of the package, it will move once you touch it. So you need to put some tape on your aerobar, which solves this. I think Wahoo should included a little piece of rubber to prevent the motion. Overall, it works fine for me.
    Date published: 2017-06-22
    • y_2018, m_7, d_20, h_4
    • cp_1, bvpage1
    • co_hasreviews, tv_2, tr_10
    • loc_en_US, sid_WFCC1M3, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
    • clientName_wahoofitness
    • bvseo_sdk, p_sdk, 3.2.0
    • CLOUD, getContent, 88.52ms
    Product Overview
  • Weight: 0.3oz
  • Features
    For more info, see Faq
    Specs
    Reviews
