Free shipping on orders over $20!
Overview Features Reviews
TICKR RUN Heart Rate Monitor
REG: $79.99
SALE: $59.99
More Views
Bluetooth and ANT+ Heart Rate Sensor with Running Analytics
SKU# WFBTHR02R
REG: $79.99
SALE: $59.99
  • 30 Day, No Hassle Returns
  • 1 Year Limited Warranty
Reviews
Product Overview
TICKR Run is the ideal heart rate monitor for runners. It measures key running metrics, such as cadence, vertical oscillation, ground contact time, and captures your indoor treadmill workouts. Equipped with Bluetooth Smart and ANT+ dual-band technology, it connects to most smartphones and GPS watches. Pair with the Wahoo RunFit running app for personalized training zones and maximize your run by adding one of the HIIT strength workouts at the end. It is compatible with most popular running apps and is the perfect running tracker to help you meet your goals.
Dual Band Technology
Both ANT+ and Bluetooth Smart capabilities allow for a wireless connection to both smartphones and GPS devices at the same time or separately.
Real Time Heart Rate and Calorie Tracking
See workout data while you exercise, including vital metrics such as heart rate and calorie burn when connected to a smartphone or ANT+ device.
Running Smoothness™
Built-in accelerometer measures running form across three dimensions to help you improve your individual form and become a stronger runner
Treadmill Mode
Special mode for tracking speed and distance data while on the treadmill
Cadence Measurement
Replaces a traditional footpod by providing stride rate data
Additional Running Analytics
Measures several other indicators of running form including vertical oscillation and ground contact time
Visible Connection
Two LED lights show the TICKR’s device connection (blue) and heart rate detection (red)
Third Party App Compatibility
Works seamlessly with over 50 apps including Nike+ Running, Runkeeper, Strava, and MapMyFitness
Apple Watch Integration
There are two options for integration: One, connect directly to your Apple Watch as another option for gathering heart rate data in the Apple Workout app. Two, connect via the 7 Minute Workout app, Wahoo RunFit app or Beacbbody on Demand app for tracking heart rate on the watch as you workout.
Click here for TICKR RUN instructions
Specs
Dimensions (LxWxH): 2.75" x .5" x 1.5"
Weight: 8.5 grams (without strap)
Battery: CR2032
Battery Life: Up to 12 months
Sweatproof: Yes (hand washable strap)
Water Rating: IPX7 (waterproof up to 5 ft)
Strap Length: Adjustable from 23" to 48" (stretched)
TICKR RUN Heart Rate Monitor is rated 4.0 out of 5 by 37.
Rated 5 out of 5 by from Great HR Monitor I love this HR Monitor. Fit and comfort are great, works with Garmin VivoActive too. Much better and more functionality than Garmin's HR Monitor
Date published: 2017-07-19
Rated 5 out of 5 by from Exactly what I needed. I was looking for a bluetooth heart rate monitor that I could use with Strava on my iPhone during running workouts. Because I am a very happy Kickr owner, I decided to give the Tickr a try. It was very easy to set up and it works great on my runs. I am very happy with this purchase and highly recommend it.
Date published: 2017-07-08
Rated 5 out of 5 by from Reliable and accurate I use this HR monitor for cycling and running and it perfectly syncs with my ELEMNT cycling computer.
Date published: 2017-05-01
Rated 4 out of 5 by from It just works It works great. The running analytics are helpful when using the wahoo app. I also like the fact that it lights up. Then you know it's on
Date published: 2017-04-25
Rated 5 out of 5 by from HUGE improvement in my running! I bought this almost a month ago to supplement my HR watch monitor, because I wanted more precise and responsive monitoring, and it has made a huge difference! Not only that, but it's greatly helped me work on my cadence, which I didn't even realize was way too slow. Several months ago, a friend who runs marathons suggested I start this plan based on heart rate reserve. For Christmas, my wife and I gave each other the Vivoactive HR monitor, a great wrist monitor, fantastic for all day use, tracking steps, etc. However, I wanted even more precise and responsive monitoring, so I researched chest straps, and the Wahoo family of straps consistently came out on top. I bit the bullet and bought the TICKR Run. It was so easy to set up with my phone and with my watch. I had to look up the watch instructions, but it's incredibly simple - start an exercise and then hold the watch close to the strap, and you're synced! After that, it's automatic each time. After using it for a month, I have to say that it's one of the best purchases I ever made! I love running again now, and knowing my heart rate, with the audible warnings and the ability to sneak a peak to check my stride, have really improved my runs. Thanks, guys, and best of luck!
Date published: 2017-04-19
Rated 4 out of 5 by from Decent hr monitor. Bought to get the connectivity to the kickr smart trainer. Works in that regard decently. However, keeping it snapped on can be finicky. If you bump it or move it at all, it unsnaps. Fairly sensitive after a warm up.
Date published: 2017-03-28
Rated 2 out of 5 by from Sporadic run metric tracking at best Purchased this to improve my running economy by utilizing metrics. Cadence measurements were OK. I Checked using a metronome and it was close ~5 spm on the low side. Other metrics like smoothness, oscillation etc recorded about 30-50% of time - even with all settings correct. I worked with their technical service to fix the settings but still a problem. No indoor track usability. Metrics need GPS (doesn't work indoors) or treadmill setting to work - if or when they do. My fit bit can estimate distance run with good accuracy why not this device? Some HR spiking noted but not as much as my 3 yr old Wahoo HRM. Bottom line, don't buy this and count on it to give metrics when you need them. For what I purchased it for I am very disappointed after having been using it for more than a month. Just by the HRM and figure out another way to record running metrics. The Wahoo iOS apps are useless also. Wish you had a scrolling line to display data at a particular time during a run. No editing functions in the app either. Wahoo has a long way to go if they want to catch up with other fitness tracking companies.
Date published: 2017-03-10
Rated 4 out of 5 by from Second unit I like this HRM. My latest purchase was a replacement after a previous TICKR Run failed after a solid year+ of use - it started under-reading by 50%. New batteries didn't help, so I retired it and started using a Garmin pod with the Wahoo TICKR strap. New Run is good. They have changed up the strap - textured the contact pads a bit. Readings look good. Battery is easy to change (much better than the Garmin pod), and I don't seem to be getting any spikes (like was happening to a HRM USA branded dual band pod). Disappointed that the base TICKR doesn't work right reliably with the Garmin Edge head units. Yes, this is more likely Garmin's issue, but they are kind of the big dog in GPS cyclocomputers. At least the Run isn't much more expensive than the base TICKR, and both are competitively priced.
Date published: 2017-02-23
  • y_2017, m_7, d_25, h_13
  • cp_1, bvpage1
  • co_hasreviews, tv_2, tr_35
  • loc_en_US, sid_WFBTHR02R, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 18.63ms
Product Overview
Running Smoothness™
Treadmill Mode
Cadence Measurement
Visible Connection
For more info, see Faq
Specs
Battery: CR2032
Reviews
